rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
n4cho
Sep 05, 2017Apprentice
bwherry wrote:...and my satellite was disconnected again this morning. Sigh. I might have to give that beta firmware a shot...
I was having nothing but issues with the satelites disconnecting and my devices losing connection. I had the beta firmware from the link when it was available and decided to pull the trigger on Saturday. My devices have not lost internet access a single time where previously it would happen 5 times in 2 hours.
As others have posted I am sure there are some issues outstanding but it has improved my experience to the point where I am totally satisfied and may unsubscribe from being notified of posts in this thread :)
For the record, I flashed, erased the NVRAM, factory defaulted and reconfigured everything from scratch. I did NOT run the speed test. I am a happy camper for the first time in a while :)
ikjadoon
Sep 05, 2017Star
^^ I'd be cautious, though. That's what everyone said about the .18 update (for those who don't know, we've been experiencing these dropouts widely since March this year--as more people buy Orbi, more people suffer and post here).
It's like a merry-go-round of frustration: some people get off and ostensibly even more get on with the next firmware, even though most beta testers felt "really optimstic this one will really fix the disconnection issues". Somehow that didn't translate into actual stability in the final release.
I'm not counting any eggs until I see everyone with multi-manufacturer dropouts (i.e., the whole network, not a single device) state that the Orbi now performs as stably as a $400+ router should.
