rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
cinek
Sep 11, 2017Apprentice
how do the speeds comapre with orbi? I tried the velop and got between 100Mbps - 200Mbps up/down less than with orbi
jdpg2
So i am happy to report that with the current beta firmware my issues are gone. I have waited 5 days before reporting just ot make sure i had no other gremlins. I have conducted 4 reboots and still have excelent throughput to all devices , wireless and wired, connected to both the main and satellite unit.
- My Orbi is in AP mode connected to an Untangled UTM router
- I have a 300/15 Mbps internet connection and get on avg 240/10 Mbps on both satelite and base orbi units with QOS enabled on my UT router.
- I have the guest network turned on (which btw is a VLAN internal to the Orbi)
- I have 20+ devices connected on avg.
The secret sauce for me was doing a full factory reset before (1.12) and after i flashed the router with the beta firmware (2.0) . I suggest anyone having issues, open a ticket and get the level 2 rep to send you the beta firmware.
- cinekSep 11, 2017Apprentice
thanks for letting us know. That does sound promising. Hopefully v2 will be out soon.
edit: what's the full version of the beta firmware you have? Is it 2.0.0.64?
- jdpg2Sep 11, 2017Apprentice
2.0.0.66
thanks, that seems newer that what we've seen in the past
- Tigerman4LSUSep 11, 2017Star
Sunday is automatic firmware upgrade day. My router and two satellites were upgraded v1.12.0.18. One of them is not showing in the webGUI as a satellite. I have tried doing a factory reset and resyncing with no luck.
This product is starting to annoy me more and more.
Did you just get your Orbi? if not, i am surpised they didnt update well before Sunday.
I suggest you manually update the Satelite via its own web UI first , then do the main Orbi via its own webUI next, then resync if the sateleite doesnt find the main unit after a few minutes.
I have had it for a couple months. Have always downgraded as v1.12.0.18 has horrible performance. I lose 50% in performance with it on my wireless devices.
i would seriouly consider giving netgear a call and try the beta. If not then i would telnet in and update the vram to prevent the FW updates after you roll back to 1.11....
I had similar issues with throughput with 1.12 but after a really clean reset (as stated in my prior post) and a hard reboot every sunday night at midnight (i have both devices pluged into smart outlets so its automated) , the only issue i was left with was my Samsung S8+ would always drop its connection. The beta has sorted this and i have no issues thus far
