rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
tpgall
Sep 14, 2017Guide
Nice try guys but a fail. I upgraded to version 2 and within 2 hours everything was locked up. No internet access or WiFi access. Same as the previous versions. Until you perfect the firmware, the system is garbage. I have an expensive 6 month old paper weight. Not a complex network. One satellite and 22 devices connected to a Spectrum cable network thru a SB3400 modem.
It is obvious you have no clue as to what is wrong with these units. They should be recalled.
I am going to post to Amazon and other boards the truth about Orbi.
spinkick
Sep 14, 2017Apprentice
Its perplexing how some people have 0 problems and others have total trainwrecks. There has to be something causing this. My system is flawless, and I feel for you guys with issues.
