jpmpls99
Jun 12, 2018Aspirant
Help with Set-up RBK50 - Centurylink Fiber
I am hoping that someone can provide set-up for a non-technical user. I was recently upgraded to Centurylink 100Mb service with Fiber. I do not (or won't soon) use CL phone service, nor do I use Pris...
st_shaw
Jun 12, 2018Master
jpmpls99 wrote:
Thanks for the response. I just wanted to make sure I fully understood. I had no idea the two forumns were so closely linked. No offense intended. I'm going to try it tonight.
No problem. The forums aren't linked, but I've been a member of dslreports since 2000.
Let me know if you have any questions. My suggestion to use Orbi in Access Point mode is the easiest to setup with Century Link and will give you the full benefits of Orbi's WiFi coverage. I'd suggest starting with that first, to see how Orbi works for you. You can try the more complex setups later, if you decide you want to.
cwjones
Oct 29, 2018Aspirant
Pointer to discussion over on DSL Reports?
- FURRYe38Oct 29, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. - st_shawOct 30, 2018Master
See here:
http://www.dslreports.com/forum/r31996958-Orbi-wifi-connection
