davidjswift's avatar
davidjswift
Follower
Nov 19, 2024
Re: How to set up Orbi with optical fiber connection?
I have just had installed gifaclear fibre to the home.  They supply a Linksys router how can I replace with the Obi router ?
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Call their technical support line and ask if their service requires a user login and password.
    Typically, the Orbi router would simply replace the Linksys that they supplied.
    If there is a monthly charge for the Linksys, it could be returned and taken off the bill.
