Stuart07715
Apr 16, 2018Aspirant
Netgear orbi RBR50
Please help I have brought an orbi system with 1 satellite and wish to extend the coverage to another part of the house which has very poor coverage, do I have to use another orbi product ie satellit...
tsig
Apr 16, 2018Luminary
I had one of these before getting the Orbi and continue to use it and it works fine.
Streak2
Apr 16, 2018Master
You could look at wifi extenders but they need to be carefully placed to ensure a decent input signal.
There are also the powerline extenders that work via the mains.
Whatever you choose make sure that the vendor has a good return policy in case it does not work in your environment.
Of course running an ethernet cable would be the most reliable but I guess you dont want to go wired!
