Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Feb 28, 2019Guru - Experienced User
Either method does the same thing...
Damit1 wrote:
Does a reset from GUI would make it right?
or got to be HARD RESET from Reset hole
Jeremyinsf
Feb 28, 2019Apprentice
I used the GUI.
