Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
randy915
Mar 01, 2019Initiate
Manually updated RBS50 to 2.2.1.212 and everytime it came up it would crash the RBR50 to the point where I had to turn off the satellite, update the router to 2.2.1.212, and then do a factory reset on the satellite so that the pair can talk.
Once I got through that the satellite update to 2.3.0.32 followed by the main router went flawlessly.
Fingers crossed but I have a strong feeling we have finally made it past the point where we will have to do factory resets for future firmware updates. Having own this system for over a year now it's nice to see the firmware finally beginning to mature. Good work NG team.
gHiDoRa
Mar 01, 2019Aspirant
where I can get the V2.2.1.212? Thanks.
- randy915Mar 01, 2019Initiatehttps://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
Note this is only for RBK50 kit. - CrimpOnMar 01, 2019Guru - Experienced User
gHiDoRa wrote:
where I can get the V2.2.1.212? Thanks.The Netgear Download Center: https://www.netgear.com/support/download/
Key in the model number "RBK53" and it will bring up links to both the intirim 2.2.1.212 and to the final 2.3.0.32.
Through 2.2.1.210, there was a limit on the size of the firmware file that could be downloaded, and 2.3.0.32 exceeded the limit.
You must download and install 2.2.1.212 first, and then immediately install 2.3.0.32 Netgear states in the release notes that "212" is intended only to reset the image size limit and is not to be run permanently.
