Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Mar 25, 2019Guru - Experienced User
Can you see if you can update your system to v44?
DougB628 wrote:
So my Orbi router factory reset itself again last night. I wasn’t anywhere near it this time. This time I had backed up the configuration, so I was back in business in just 10-15 minutes. Since this happened after the firmware upgrade I’m a little more suspicious of the router now, although it could still be an unknown firmware bug.
No_username
Mar 25, 2019Aspirant
My RBR50 auto updated to fw 2.3.1.44, not sure when update happened. Manually updated to fw33 2 or 3 weeks ago.
Experiencing intermittent loss of wifi.
- FURRYe38Mar 25, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?Try enabling Beamforming and MIMO.
Experiencing intermittent loss of wifi.- 1midniteriderMar 28, 2019GuideAny progress on this issue?
- FURRYe38Mar 28, 2019Guru - Experienced User
Has a factory reset been performed if needed?
