dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
itzcoatl13
Jan 19, 2018Guide
How did you get into the NVRAM and what setting did you change?
tagteam
Jan 19, 2018Virtuoso
See the instructions in the link below.
https://community.netgear.com/t5/Orbi/The-2-1-2-18-nightmare/m-p/1490248#M21767
- wootiesJan 19, 2018Star
tagteam's instructions above on disabling auto-update saved me from going to pick up a google wifi (thank you for that). Reverting to older firmware is the answer, unfortunately.
- madbrainJan 19, 2018Luminary
wooties wrote:tagteam's instructions above on disabling auto-update saved me from going to pick up a google wifi (thank you for that). Reverting to older firmware is the answer, unfortunately.
It may not have updated immediately, but until you have run it for a couple of weeks and it hasn't upgraded, don't assume it will stay at whatever firmware you installed. I have never managed to make my Orbi stick to a stable version (way back in 1.11 and below series) more than a week, even with all the telnet fixes.
- OrbiFANJan 19, 2018Aspirant
Before Zero issue and after update Zero issue.
Thanks Netgear !
