dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
mealto
Mar 18, 2018Star
Hey everyone. V2.0.1.4 is out. It is a smaller digit than 2.1.2.18 but it is a newer version. Force an update to this or do a manual "upgrade" if needed. It's way more stable than 2.1.2.18.
DerAusgewandert
Mar 18, 2018Star
Sorry mealto, this is old news. Netgear stopped autoupdates with V2.0.1.4 some time ago, because none of the 2.1xx firmware versions were stable enough. Read the threads. This is taking it back to a stable version before they figure out the problems going towards 2.2. It's a step backwards to ensure they are not getting even more fire from new customers buying the routers now.
cheers
- mealtoMar 18, 2018Star
DerAusgewandertwrote:Sorry mealto, this is old news. Netgear stopped autoupdates with V2.0.1.4 some time ago, because none of the 2.1xx firmware versions were stable enough. Read the threads. This is taking it back to a stable version before they figure out the problems going towards 2.2. It's a step backwards to ensure they are not getting even more fire from new customers buying the routers now.
cheers
Not sure what the issue is with yoru old news comment. There were some recent complaints in this thread that FW is broken. I assume this is from users having issues with 2.1.2.18 as this is a thread for 2.1.2.18.
Many have found 2.0.1.4 is more stable so just giving other owners a heads up to go from 2.1.2.18 to 2.0.1.4.
- JoeCymruMar 18, 2018Virtuoso
2.2.1.18 is not unstable for everyone. It seems many are affected differently depending on use, circumstance, wired or unwired, Disney Circle, etc. New Orbis load the regression fw. Extant user can roll back manually. In my case, 2.2.1.18 upgrade worked fine. I personally am concerned about the push when the new firmware comes out, considering the issues in the past so many have experienced when new firmware is released.
- Mr-WednesdayMar 24, 2018Tutor
I'm not having any issues with 2.1.2.18 either. Everything is roses for me so far (knock on wood). In fact, I didn't even know there was an issue until I just stumbled across this thread today.
- DerAusgewandertMar 18, 2018Star
well, according to this sticker post by AmitR from Netgear it looks more like an overall issue with 2.1 fw.
https://community.netgear.com/t5/Orbi/OrbiOS-MR-2-1-issues/m-p/1506307/thread-id/23649/highlight/true I don't think it matters whether not everybody was affected. If a large number is having problems randomly, then they released something they should not have. If you change something with your setup in the future you may end up in the same situation as others who are now willing to return their non-working system. It's a pitty they got here this way and apparently putting their experts into a room for a week and still not solving the problem seems to indicate it's a much bigger problem.- MudManMar 22, 2018Guide
I spent over half a day figuring out what the hell was going on, thinking I had a device problem or bad ethernet cable. Only to discover it was the RBR50 and the satellite connected via ethernet. I've never had a problem until 2.1.1.18 was released.
Here's the steps I did to disable the auto update and flash back to version 2.1.1.16
1) Go to Advanced, Security, Block Sites and add the following sites.
http.fw.updates1.netgear.com
downloads.netgear.com2) Download version 2.1.1.16 for both the router and satellite.
3) Flash the satellite first and then the router.
So far everthing has been working and I no longer have to worry about auto updates.
Later,
Don
