tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
schumaku
Aug 26, 2018Guru - Experienced User
FURRYe38 wrote:
The high 5Ghz channels all dedicated for the wireless back haul, regardless of wired backaul. NO user access or configuration enabled in the UI.
This is done because only the higher channels allow using the higher power, what is required for a fast and reliable wireless backhaul.
FURRYe38 wrote:
Not sure why they couldn't open up those channels when connected wired back haul.
Not sure how flexible things are. In a pure wired backhaul environment the more powerful (and depending on the model variant more capable) backhaul radios could serve as additional 5 GHz APs, too. But then, what has to happen if somebody does ad-hoc add a wireless satellite?
toe
Aug 27, 2018Apprentice
Not entirely true. Max transmit power of wireless devices is strongly regulated, you can get FCC/CRTC fines if you exceed it. For the US, the 4x4 radio on the Orbi is transmitting at 1000mW or 30dbM, exactly the same power level as the 802.11n on the 2x2 radio.
- schumakuAug 27, 2018Guru - Experienced User
Hm, pretty much convinced Orbi does use 802.11ac on the 2x2 radio, too. Of course it's regulated:
- Originally, U-NII Low (U-NII-1) was on 50 mW indoors only, current is 1 W power and max 4 W EIRP (max antenna gain 6 dB) for non-point-to-point.
- U-NII Mid (U-NII-2A) is max power 250 mW and max 1 W EIRP.- U-NII Upper (U-NII-3) is max power 1 W and EIRP up to 200 W.
Further limitations apply without TPC.
Hope this clarifies why Netgear does use the high channel set for the wireless mesh.- tln741Aug 27, 2018Star
Hope this clarifies why Netgear does use the high channel set for the wireless mesh.And yet the power output on the 5G backhaul is the same as the 5G wifi channels: 36 dBm.
- schumakuAug 27, 2018Guru - Experienced UserBlack magic 36 dBm from 250 mW on the middle band using the same antennas?
