walkerx
Feb 24, 2019Guide
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.
I...
- Mar 07, 2019
resolved the issue
picked up google wifi - setup in about 20 minutes - all devices working and so is their app
wifi might not be ac3000 but at least everything works
Mar 06, 2019Guru - Experienced User
Possible new bug for the app. You might contact NG support and ask about this:
walkerx wrote:
Even after further reboots, the wired satellite still shows as not connected/online in the app, yet through browser it is fine.
walkerx
Mar 07, 2019Guide
resolved the issue
