NigelCheetham
May 19, 2018Aspirant
ORBI Blocks Access to Playstation Network
We recently installed the Orbi system with two satellites, to replace my existing Netgear Router (model R6400). Once setup, my son lost his ability to log into the Playstation network (he has a Plays...
May 21, 2018Guru - Experienced User
Whats the Mfr and model of the ISP modem the router is connected too?
Try change NAT Filter to Open under Advanced settings/Wan setup.
NigelCheetham
May 23, 2018Aspirant
Cable modem is:
Arris model number: TM1602.
The internet provider is: Optimum (CableVision).
I opened the NAT filtering and the Network Status screen started showing the Playstation network (before it would just show that we were connected). However, the Playstation now reports that the Playstation Network is currently unavailable.
Thanks for your help though - I think we are one big step closer to domestic bliss!
Best regards,
Nigel
