des421
May 27, 2018Tutor
Orbi DNS priority
 RBK50, 1 satelite, both with latest firmware (2.1.4.10). So much for assumption. You would think that primary/secondary/third DNS addresses were prioitized? I.E. the device would try to use the prima...
TheEther
May 27, 2018Guru
I'm pretty sure Netgear uses dnsmasq. The default behavior of dnsmasq is to query any of the servers it knows about. This would explain the behavior you are seeing. dnsmasq does have a strict order option. Maybe you can ask Netgear to offer it as an option in their Idea Exchange for Home forum.
- des421May 27, 2018Tutor
Done! Thanks: DES
