MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Retired_Member
Nov 06, 2019
FURRYe38 wrote:Others are reporting v.38 working just fine. A reset seems to be key here:
Bad advice.....NG has reported that this firmware is the root of the problems discussed here. WHY have people waste their time as you suggest?
MikeG63
Nov 06, 2019Apprentice
Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really required is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
- Retired_MemberNov 06, 2019
MikeG63 wrote:Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really eeded is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
Smart man. Your network and peace of mind thanks you
- MikeG63Nov 06, 2019Apprentice
Indeed it does :smileyvery-happy:
- dsc_dewainNov 07, 2019Guide
Did the firmware get pulled. Been monitoring forum, and when I checked for latest version on my orbi. It says 2.3.5.30 is the latest now? No updated version available.
MikeG63 wrote:Indeed it does :smileyvery-happy:
- FURRYe38Nov 06, 2019Guru - Experienced User
Thats good for you, glad your appart of the group that didn't need a reset. Some don't and yet there working on v.38. Others seem to need a reset and then things work:
At each FW release there seems to be this mixed bag of users with issues and some that don't see issues after a update and some that do and need a reset. I do agree, NG needs to make the FW update more stablized and less automatic and more automated.
I prefer the manual FW load and reset and setup from scratch. No problems with this method. This is my perference.
Enjoy.
MikeG63 wrote:Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really required is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
FURRYe38 wrote:I reprefer the manual FW load and reset and setup from scratch. No problems with this method.
But.....you've never explained why you would execute a manual update in the first place, especially if your network is working fine.
- agneevNov 07, 2019Aspirant
Not related to this topic but, does the satellite need to be in close range when setting up from scratch?
- tomschmidtNov 08, 2019Virtuoso
I likewise have experienced the device naming issue with the V2.5.0.38 firmware release. The device names became completely messed up with the firmware update from V2.3.5.30. I also reset to factory settings (both through the GUI and repeated with the reset button) and manually reprogrammed the router and found that I could not edit several of my devices model, name or type. I have attempted to roll back to V2.3.5.30, but the router and satellites upgrade themselves again to the broken firmware when connected to the internet.
It is very disappointing that a company like Netgear continues to release buggy firmware on the Orbi hardware.
- FURRYe38Nov 08, 2019Guru - Experienced User
NG is aware of the naming device issue. Its nothing critical so if your bothered by this, you can down grade and wait for next FW update.
tomschmidt wrote:I likewise have experienced the device naming issue with the V2.5.0.38 firmware release. The device names became completely messed up with the firmware update from V2.3.5.30. I also reset to factory settings (both through the GUI and repeated with the reset button) and manually reprogrammed the router and found that I could not edit several of my devices model, name or type. I have attempted to roll back to V2.3.5.30, but the router and satellites upgrade themselves again to the broken firmware when connected to the internet.
