Chadweasel's avatar
Chadweasel
Orbi Satellite and firmware problems
I recently installed my orbi system with a satellite. My problem is my satellite has the same name as my router but the satellite still uses the factory password while my router is using the password ...
  • webminster's avatar
    webminster
    Mar 05, 2018
    You can't set the password on a satellite via its UI page, there's no such option.  You might try, after verifying the router and satellite are connected, to reset the password through the router (change it to something, then change it to the desired one).  This worked for me when I had a similar problem where the satellite didn't get a full sync and still had the factory default.
