TomiPhone's avatar
TomiPhone
Follower
Dec 02, 2018
Orbi setup as Router or AP?
Hi there, Just purchased the Orbi and was wondering what the best setup is? I have a Ziggo modem/router. Should I setup the Orbi as router (Ziggo in bridge mode) or as AP? Thanks in advance for your...
  • st_shaw's avatar
    Dec 02, 2018
    There is no right or wrong answer.  If you like your Ziggo's router features, then use Orbi in AP mode.  If your Ziggo modem/router has bridge mode, then you have the option to use Orbi in router mode. I use my Orbi in AP mode because I have another router with better routing features and no WiFi.
