ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
aksme
Nov 25, 2017Aspirant
Hello all,
I have the Orbi bundle from Costco and have found that the single SSID approach is not working with half of the devices I have at home.
The newer devices (laptops and phones) connect just fine and I have great coverage.
However, some of the my older laptops when trying to connect are just returning an error "cannot connect to this network". This is after providing the correct password.
Does anyone know if there is a way (for the layman) around this without having to buy new laptops?
khad
Nov 25, 2017Apprentice
st_shaw is spot on. I wrote up a post that describes How to set a separate SSID for the 5 GHz network on your Orbi.
