AmitR
Apr 24, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
netadmn
May 05, 2018Apprentice
setham wrote:
ZoneMaster wrote:
In this day & age automatic updates are necessary. There are too many network threats to leave the possibility of a vulnerability being unpatched.
I agree that an auto-update option should/must be enabled by default but with an option of turning it off.
Be smart about it. Roll out slowly to your users so you can get some feedback AFTER regression testing is complete in house. Then schedule the update at a time that is less likely to be busy for most users... say 3AM. I still think the idea of flashing the Orbi LEDs a color/sequence to notify/warn those users would be appropriate. Then they would at least know since these things sit out in plain view. My samsung smarthings hub automatically updates but they generally email me to let me know it's happening and what to expect.
I guess I'm next going to figure out what update servers samsung uses for thier firmware updates and just block them at my firewall.
netadmn
netadmn wrote:
I guess I'm next going to figure out what update servers netgear uses for thier firmware updates and just block them at my firewall. (fixed samsung -> netgear)
So it looks like updates1.netgear.com is the domain to block via your favorite dns sinkhole. I just created an alias to point to my pfblockerng alias in pfsense. Easy enough to disable/enable. For everyone else... look into something like pihole to create your own dns block list. Or, do a nslookup on that domain and create a static route in Orib to a non existent next hop(s)... Problem with this approach is those IPs can and may change often depending on where you are if its a cdn.
- netadmnMay 05, 2018Apprentice
Won't work for me since I'm AP mode but it should work for those in router mode... if you can ping updates1.netgear.com but not after... you know it worked. Trying to FTP to those addresses after (using cli/filezilla) should fail.
I can see my images when I'm logged in but not when I browse a public page... so here is what I uploaded in case you can't see the images.
- FURRYe38May 06, 2018Guru - Experienced User
Try blocking ports 443 and 20-21 to the routers IP address.
- timchMay 07, 2018Luminary
Well I have been up for 11 days on 2.1.4 now and it is rock solid. Running 1 wireless sat and 1 wired. Speed and reliability is great. I am in AP mode and have mu mimo, daisy chaining, fast roaming all enabled.
