AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
RocketSquirrel
May 08, 2018Luminary
steve8411 wrote:
Add me to the list of continued failure with Apple products...
RBR50 ... while the beta was actually improved, the production release is actually worse.
My iPad almost never gets internet (even though its connected to Wifi) after waking up ....
Another disappointment.
That is so weird. We have 2 iPads & 2 iPhones in my household, and they all connect perfectly every time. Trust me, I'd be hearing about it from my wife if she couldn't get Internet. I'm running V2.1.4.10 with wired backhaul.
It wasn't easy to get everything working. I did a very slow step-by-step, basically
1. Shut down modem, router, and satellites.
2. Power up modem, wait for it to settle to steady state seeing Internet.
3. Power up router, wait for it to slowly settle to steady state. Verify it's working with wired & wifi devices.
4. Power up 1 satellite, wait for it to slowly settle to steady state. Verify it's working with wired & wifi devices.
5. Power up any remaining satellites 1 at a time.
I don't know why, but the Orbi router seems to want the modem freshly booted before turning on the Orbi. The instructions imply that. Good luck.
Oceanwaves
May 08, 2018Star
I was also hit by the FW update to 2.1.4.10 last week. Luckily one day after I returned from holidays, as the whole network was down in the morning. Thanks to this forum I was able to return to 2.1.2.18 and disable automatic updates (as described here). However, today (exactly one week later) the same happened again: network down, AP and satellite are on 2.1.4.10 :smileysad:.
I'm using the RBK20 and I need Ethernet backhaul and daisy chain. AP ist placed on second floor and satellite on first floor, between them just the ceiling. But it is made of armored concrete. I get a bad WiFi connection at 2.4 GHz without Ethernet, if AP and satellite connect to each other at all. And I have two simple switches between AP and satellite, so I need daisy chain option, too. The RBR20 has to be in AP mode as I have cable internet and the modem is integrated into the ISPs router (AVM Fritzbox 6490, I'm from Germany).
I've downgraded AP and satellite to 2.1.2.18 again and checked the auto update options on the RBR20, but they are all still set to zero:
root@RBR20:/# nvram show | grep -E "orbi_auto_upgrade|auto_check_for_upgrade|auto_update" orbi_auto_upgrade=13064382 auto_update=0 auto_check_for_upgrade=0
So everything looks good, nevertheless the RBR20 automatically updated to 2.1.4.10 :smileysad:.
- RocketSquirrelMay 08, 2018Luminary
I don’t understand “I need Ethernet backhaul and daisy chain.”
My understanding is that daisy chain allows satellites to talk to each other WIRELESSLY without going through the router. If the sats are wired, they already have direct connectivity to the entire LAN.
Am I misunderstanding?
- OceanwavesMay 08, 2018Star
When I set up the RBR20 and the RBS20 using Ethernet backhaul I found this description on Reddit. It is my understanding that Daisy Chain is required because there are two switches between AP and satellite. When I disable Daisy Chain the satellite tries WiFi backhaul although it is wired.
Update: Exactly 1 hour after downgrading RBR20 and RBS20 to 2.1.2.18 the router was updated to 2.1.4.10 again :smileyfrustrated:. I disabled Daisy Chain and both Orbis rebooted (satellite was still on 2.1.2.18). The status page showed "wired" and the backhaul status switched between "Connected" and "Bad". A few minutes later the satellite was automatically updated to 2.1.4.10, too.
Network was down again.
That's it. I need my LAN as I'm working from Home Office today. I switched the Orbis off and activated the WiFi on my ISP's router again.
Does anybody know whether the Google WiFi or Ubiquiti support Ethernet backhaul and AP mode for the router?
- FURRYe38May 09, 2018Guru - Experienced User
Did you try a reboot of the system or full factory reset and set up from scratch after it updated to v2.1.4.10?
