AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
RocketSquirrel
May 08, 2018Luminary
I don’t understand “I need Ethernet backhaul and daisy chain.”
My understanding is that daisy chain allows satellites to talk to each other WIRELESSLY without going through the router. If the sats are wired, they already have direct connectivity to the entire LAN.
Am I misunderstanding?
Oceanwaves
May 08, 2018Star
When I set up the RBR20 and the RBS20 using Ethernet backhaul I found this description on Reddit. It is my understanding that Daisy Chain is required because there are two switches between AP and satellite. When I disable Daisy Chain the satellite tries WiFi backhaul although it is wired.
