Christiaan11
Apr 04, 2018Apprentice
Ping spikes and packet loss on WiFi
Hi, I’m having trouble with my orbi router with online gaming over WiFi. For the rest it works extremely well with high speed (400 down 40 up) and very low pings (10ms), all on WiFi. However with onl...
Apr 04, 2018Guru - Experienced User
Its still in flux. Of course anything is possible. Was a few that received this via auto update.
They added more models and beta availability to the beta test thread so there still coming out with FW. :smileywink:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
Besure to reset and set up from scratch. Its still needed for a bit longer. At some point the resets wont be needed from what I'm told.
webminster
Apr 04, 2018Luminary
There have been many people here that have measured bad ping RTT and packet loss on the Orbis, even when connected to the router, and pinging a LAN address (never mind WAN). I experience it as well, with ping times swinging wildly from say 3-4 ms to well over 150-200 ms for a few packets.
I've seen better and worse performance across several firmware revs, but no version of 2.x that behaves well. Also regardless of the standard comments, disable all the options, change the channels.
- Christiaan11Apr 06, 2018Apprentice
Hi,
I have set the Orbi and satellite to factory settings. The settings you suggested were already turned off. I also wired the ISP router again since to be sure.
I see improvements while gaming online (see pingplotter printscreen) but not enough to make it good enough to play over wifi. I think I will give up and accept the fact that I need to game with ethernet only!
Thanks for your help!
- FURRYe38Apr 06, 2018Guru - Experienced User
Ethernet will always have better and best performances over any wifi. Ethernet is perferred for gaming.
