Lijo
Sep 27, 2026Aspirant
Port Forwarding / Port Triggering
Loading the page for Port Forwarding / Port Triggering fails with an error. Uncaught SyntaxError: Invalid or unexpected token forwarding.htm?model…ersion=V2.7.5.6:145 Uncaught ReferenceError: m...
Sep 28, 2026Guru - Experienced User
How are you configurng the Port Forward or Trigger? What port numbers are you using?
What browser are you using?
Did you first disable uPnP before configuring PF?
The Orb AC series is EoL so may not see any fixes. You should give 3rd party FW Voxel a try.
