AlainDeMan
Dec 05, 2025Aspirant
Printer behind ORBI not found
Dear friends, I have a standard configuration, with a WiFi modem from my Telco provider in the basement, and an (RBR50) ORBI access point (set-up as Router) in my kitchen. Both have a different S...
Dec 05, 2025Guru - Experienced User
Make sure the printer and the printers app on the mobile device are connected on the same network. Either on the ISP router or Orib router system.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure to contact the printer Mfr for additional help and support for there product.
- AlainDeManDec 06, 2025Aspirant
Thank you for this detailed advise !
I have a 3 floor house (with thick reinforced concrete between the floors), and need WiFi on all three floors. So I need the Wifi from my Telco modem on the ground floor, the Wifi from my Orbi on the second floor, and the Wifi from an Orbi Satellite on the 3rd floor. So I need the WiFi radios on all the equipement (my Telco modem, my ORBI and my ORBI Satellites). I understand that the NAT condition is probably the source of my problem, so what's the best solution ? Keep my Telco modem as (only) router and reconfigure the ORBI as an Access Point ?
Appreciate your advise & help. Thanks !
