meach13
Aug 06, 2018Initiate
RBK50 Satellite Speed
Hi Everyone,
New to the forum and did a little searching. Does Orbi software have or do they plan to add speed between Satellites? I do show it is on 5g but not the actually connection speed betw...
Aug 06, 2018Guru - Experienced User
No idea, you can made a request here for it:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
The speed rates should be at max per the specs seen for the 40 or 50 series.
meach13
Thanks,
It would just be easier to be able to find tune the placement of the satelitte. Right now I am getting around 100 meg but every blue moon it will get around 280.
I will put a request in.
