sebastian76
Sep 21, 2018Follower
RBK50 with existing router
Hi,
I'm planning to buy mentioned kit RBK50, but i have important question and can't find clear answer.
Is it possible to configure RBR50 as normal AP without router function ? I have other r...
AC641
Sep 22, 2018Luminary
sebastian76 wrote:
Hi,
Is it possible to configure RBR50 as normal AP without router function ? I have other router and getting internet via fiber. I have so many options configured on this device and I'm very happy about it. I would like to use orbi only for wi-fi with same addresses which I have on lan side of my existing router.
If it is possible then where I should connect ethernet cable to RBK50 from my existing router ? to Internet port ? or ethernet port ? Just to have on wireless same ip addresses like i have on wired lan and see whole local network from wireless devices.
If RBR50 will be working as AP only (not router) then - can I still connect two satellites (RBS50) ??? Or it will only work if RBK50 is configured as router ?
Thank you all in advance for simple answer.
Ssebastian
Yes, you can run the Orbi in AP mode as you wish to.
Regardless of whether you use Router or AP mode you connect the cable from your existing router to the Internet port of the Orbi Router.
You can add satellites regardless of whether you use Router or AP mode.
