Animal827
Apr 13, 2026Aspirant
RBR40 Blinking White Light
At about 3pm today I started experiencing connection issues on some devices, so AI decided to reboot the RBR40. It will not reconnect to my Verizon modem . It remains in a pulsating white light. ...
- Apr 14, 2026
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Can try option #2 first...
CrimpOn
Apr 13, 2026Guru - Experienced User
The firmware release should not cause this problem. There should be no harm in updating the firmware, but I am not confident that would solve whatever has gone wrong.
If you want to update the firmware, download the router and satellite files from the Netgear support site to the laptop
https://kb.netgear.com/000070458/
- Extract the *.img files from the router and satellite download.
- Connect the laptop web browser to each satellite using the satellite IP address.
- Use the Firmware Update menu item to update firmware on all satellites.
- Finally, connect to the router and manually update the router firmware.
It would be a good idea to make sure you have a backup of the configuration before starting any updates.
Also would not hurt to make two checks:
- Does the cable between router and modem appear solidly connected?
- If you connect to the router web interface using the laptop what does it show about the WAN connection?
On the Advanced Tab, click on Show Statistics.
