NvdM
Nov 29, 2025Aspirant
RBR50 signal lost multiple times during the day when having teams calls
I have a RBR50 router connecting to two sattelites. One on each floor. On the 1st floor the connecting is lost several times during the day. On the 2nd floor the issue is the same. How can I impr...
Nov 29, 2025Guru - Experienced User
NvdM wrote:On the 1st floor the connecting is lost several times during the day. On the 2nd floor the issue is the same.
How long has this been happening?
What status are you seeing for the backhaul connection?
- NvdMNov 29, 2025Aspirant
It is happening for a long time already. I am not so technical. What do you mean?
- StephenBNov 29, 2025Guru - Experienced User
Months? Years? Since you first installed it?
Log into the admin web ui, and then click on the "attached devices" tile on the upper right.
You'll see the connected satellites at the top, and the far right column is "Backhaul Status". The "Connection Type" field is also relevant.
NvdM wrote:
Wired devices don’t drop
Are any of these connected to the satellites? Or are they all connected to the router?
Since it is installed but it seems to occur more and more recently.
Backhaul status is Good over all devices. Connection Type is 5G
StephenB wrote:
Are any of these connected to the satellites? Or are they all connected to the router?Also connected to the satellites. Like Philips Hue and Tado for home automation is connected to the sattelites.
