BrainFart
Jun 22, 2018Tutor
RBR50/RBS50 Firmware update
Hi all,
Newbie to all of this stuff and am looking for some help / advice wrt updating my Orbi system.
It was a Costco buy 1 router (RBR50) & 2 satellites (RBS50).
When I first bought them ...
- Jun 23, 2018
Yes I prefer manually upgrading myself. ALways have. Yes there was a sequence and yes, satellites should be updated first then the router when you do manually update FW.
Yes, when I manually got everything updated to v.10, I chose to update using the routers UI for both router and satellite when .v16 was available. and let the router push the update for both instead of manually downloading and sending the file.
michaelkenward
Jun 25, 2019Guru - Experienced User
2022 wrote:
anyone can help me to remove branded firmware and install original netgear firmware!!
Who sold you this Orbi device?
2022
Jun 25, 2019Tutor
i purchase it from isp provider
- FURRYe38Jun 25, 2019Guru - Experienced User
Sorry, if the TFTP method fails, theres nothing else that can be done. You'll need to contact your ISP or return there Orbi system and buy a retail Orbi system then you can take advantage of the FW updates directly from NG.
2022 wrote:
i purchase it from isp provider - michaelkenwardJun 25, 2019Guru - Experienced User
