beckss1
Dec 15, 2018Tutor
SATTELITE DROP-OUT
Hi,
Last day I have a problem with my ORBI system (RBR40 - V2.2.1.210 and RBW30 - V2.2.1.204) and all attempts for resolving not help me
I mean reset sattelite and re-add it again help me for not...
Dec 15, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
beckss1
Dec 15, 2018Tutor
Thanks for providing quick answer, but only after that I downgrade sattelite version to V2.1.4.16_1.0.17 it started to work properly without any discoonect issues.
Thanks and regards,
- FURRYe38Dec 16, 2018Guru - Experienced User
Glad you got it working,
Try the suggestions next time if you upgrade to 210. v210 is working for others.
Enjoy.
- beckss1Dec 17, 2018TutorThank you for replying.
I checked via GUI and via mobile application, that satellite indicate me available update and after downgrade version I not disable automatic upgrade it made this (I mean came back to latest version) . From last Friday when I open ticket satellite work without drop out. Then probably this is solution for this issue.
Thanks and regards.- FURRYe38Dec 17, 2018Guru - Experienced User
Enjoy. :smileywink:
