Krast
Jan 10, 2018Follower
Setup Daisy Chain
I try to Setup a Daisy chain topology. The Second Satellite Connects only to the Router But Not to the First satellite. In which Sequence I have to Start the Setup and Press the Sync Buttons? i ha...
DarrenM
Jan 12, 2018Sr. NETGEAR Moderator
The satellite may be getting a stronger signal from the main router and is connecting to it rather than the other satellite.
DarrenM
jmschnur923
Jan 12, 2018Luminary
Try moving the 1st sat closer to the 2nd and the 2nd further from the router. Then hit the sync button on the 1st sat and then the second. This worked for me.
