cmftblynu
Jan 19, 2018Star
The 2.1.2.18 nightmare
I won't bother going through how angry I am at Netgear for this firmware MESS (I already have in several posts) since they don't bother offering ANY customer support after they screw you out of your ...
May 09, 2018Guru - Experienced User
Did you try a reboot of the system or full factory reset and set up from scratch after it updated to v2.1.4.10?
Oceanwaves wrote:
I wonder why everybody seems to have problems with FW 2.1.2.18 as this is the only FW working w/o problems on my RBR20/RBS20. RBR20 is in AP mode and I need Ethernet backhaul and daisy chain option as I have armored-concrete in the ceiling between 1st (satellite) and 2nd floor (AP) and two simple switches between the AP and the satellite. Last week my whole network was down in the morning because AP and satellite had updated to 2.1.4.10. Downgraded both to 2.1.218 again, disabled auto update as described above and everything was fine.
Until today. Exactly one week after downgrading my Orbis were updated to 2.1.4.10 again automatically. And auto update is still disabled:
root@RBR20:/# nvram show | grep -E "orbi_auto_upgrade|auto_check_for_upgrade|auto_update" orbi_auto_upgrade=13064382 auto_update=0 auto_check_for_upgrade=0Network was down again and I downgraded both to 2.1.2.18 again. Still wondering why they were updated automatically.
Oceanwaves
May 09, 2018Star
See my reply here.
