Bayamon62
Jul 21, 2018Guide
TP-link switch sg-108 wont connect to internet
After connecting my Orbi RBK33 ( rbr-40 router) my TP-Link TL-SG-108 ethernet switch will not connet to internet ,i have a ethernet cable from the orbi to the 8 port switch and nothing connected to i...
thombe
Jul 23, 2018Apprentice
I have the TL-SG-108E which is managed. (v3)
I read somewhere before (can't remember full details) but if you have the E managed model try disabling the IGMP Snooping.
I'm not currently using it with my Orbi as I'm experimenting wiht my previous Asus routers since they introduced AIMESH.
(1x DSL-AC68U and 2x RT-AC68U) if they are stable then I'll sell my Orbi, only as no need for both.
BarryTreg
Hi I have this switch on my Orbi working fine. There was a bug in the switch'd firmware where it didn't always save your settings and would revert to defaults when rebooted. This got fixed by installing the latest version of the software. Maybe there's an issue for you there as well?
