dangitzin's avatar
dangitzin
Using Ethernet ports on the Satellite
New to the Orbi system. So the satellite has Ethernet ports... My question is, will I be able to connect a pc, console, or anything for that matter in the ports and have it be supplied with internet? ...
  • AC641's avatar
    Feb 14, 2018
    Yes, you can use it as you describe.  I have my Hue hub plugged into one of my satellite ports and have, in the past, had my laptop connected for testing puposes.
