In5iDi0uZ
Jul 22, 2019Guide
V2.3.5.30 Broke Bridge Mode Dont Upgrade
Frustrating weekend troubleshooting. I use Orbi RBR50 and a RBS50 also use a R7000 in Bridge mode for my pc, using 5GHz, for last couple years. I had updated the Orbi and the R7000. After this It wo...
Oct 10, 2019Guru - Experienced User
You might contact NG support about this and see if they might be able to fix the R7000 wireless bridge mode to work with the Orbi system for long term use. They fixed the EX8000 and 7700.
In5iDi0uZ wrote:Well it auto-updated again this morning, and broke the connection again. I downgraded and followed the steps in this link: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973/highlight/true#M10304.
I'll just keep applying this whenever the router reboots, if that's what it takes for my connection to work.
