lowepg
Dec 29, 2017Apprentice
Ready to bail on Orbi and try Velop- any tried it?
Getting frustrated by all the problems since this last firmware push....
For the $$$$ they charge for Orbi- it's just not acceptable.
Anyone try the Velop?
One thing I really like is it appears to be a TRUE mesh design- not Master/Satelite like the Orbi.
- amrobxGuide
Using a 2 node Velop right now and getting roughly 150 mbps to 200 on average with wired (usually closer to 150) per iperf3. They are easy to set up and pair, plus wired backhaul works well. Coverage is more than enough everywhere and well outside my house @ ~1600ftsq. Can’t compare to Orbi just yet, as I won’t have until next week. I will have more conclusive comparisons late next week which will decide which one I return
- Boomerang3Apprentice
I would be interested in the systems management aspects of each. I haven't come across any reviews that discuss the management of each solution.
- amrobxGuide
Velop isn’t terribly robust, either from the app or web interface. Certainly nothing like you’d see from Ubiquiti and the like. Like most mesh solutions, the general target is higher simplicity. I’d imagine orbi isn’t terribly different in that aspect. The Velop management definitely would not be one of the reasons to steer in its direction.
- DittimTutor
I checked the Linksys forums and they are having as many, if not more, issues with stable connections as Netgear.
I downgraded to 2.0.0.74 and disabled auto-update and everything is stable for me. I’m sticking with Orbi as the hardware is better and hopefully Netgear will get their act together on stable firmware soon.
I believe that the consumer mesh market is still maturing, so going with a company with a good reputation for updates, and support will be important as we proceed. My setup is rock solid, getting full speeds throughout the house. With the exception of systems management could use some upgrading, I am extremely happy.
- Silver0066Apprentice
How do you disable the Automatic Firmware update?
- tagteamVirtuoso
It is outlined in the thread below (post #105).
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
