JLauHK
May 16, 2025Aspirant
Recovering Configuration after Firmware Update 2.7.5.6
Product: RBK40
After I upgraded my firmware to 2.7.5.6, I somehow have to reset (factory setting) and lost my previous configuartion.
I have a Backuped Configure File NETGEAR_Orbi-mini.cf...
May 16, 2025Guru - Experienced User
You'll need to set up the system from scratch.
Unless you downgrade the RBR back to what you had loaded on it and generated the .cfg file long enough to maybe change the password to something that is supported on the newer FW version. Then save off the .cfg file again with the newer password set. Then re-update the router back to newer FW. All settings should be there however maybe do a reset anyways, then apply the .cfg file afterwards.
I'd take screen shots of important web pages if you return the system back to older FW so you have some backup info.
