JLauHK
May 16, 2025Aspirant
Recovering Configuration after Firmware Update 2.7.5.6
Product: RBK40
After I upgraded my firmware to 2.7.5.6, I somehow have to reset (factory setting) and lost my previous configuartion.
I have a Backuped Configure File NETGEAR_Orbi-mini.cf...
JLauHK
May 17, 2025Aspirant
FURRYe38, thanks for your speedy advice.
I would also like to know the answers to my questions 2.and 3.
- FURRYe38May 17, 2025Guru - Experienced User
If you downgrade back to where the config was first generated, then yes. If you update FW, its commended to not load the older config file as it may bring in some incompatibilites with newer FW.
Most likely yes.
