Swenson0110's avatar
Swenson0110
Follower
Nov 19, 2021
Red Light vs Amber Light On Satellite During Attempt To Reset
CONFIG:   (1) RBR50 With (2) RBS50
FW:   2.7.3.22
I reset all of the mesh devices in my home and started from the groud - up.  The router and one of the two satellights worked fine.  The other satellite gives me a red light indication when I attempt to reset it.  All the information I have seen indicates that the LED should flash amber (as the other devices did when I reset them).
I can't tell if there is an issue with the satellight or not. When I bring everything back online, the dashboard indicates that everything is working fine.
Has anyone experienced this?  Should I be concerned?
Thanks everyone
1 Reply
  • FURRYe38's avatar
    How long are you pressing the reset button for on the RBS? 15 seconds then release should do it.
