Rune777's avatar
Rune777
Red power flashes ones
Hi guys
My CBR40 just abrouptly stopped working. When i unplugg it or turn the power on off, the power LED on the front just flashes red one time then nothing. I tried to do a factory reset but still no chandge. Any suggestions on how to get the unity to work?
thanks
Rune
  • I tried to do a factory reset, and re install everything. For some reason the green LED light never comes and it cant connected to the service provider, i get a local network working but i cant connect to the internet... I know the cable connection is good as i have tried an old modem and had spectrum swap mac address... Bummer that the product only lasts two years and then breaks...
    • FURRYe38's avatar
      Can you try a different power supply with same spec as original?
      Can you access the CBRs web at all?
      • Rune777's avatar
        Rune777
        I have tried that and it doesnt help. The power works and i can connect locally to it, it but it fails to connect to the cable service provider. The LED light on the front dont glow, but the rings on top does. so when im resetting it up the network light never comes on
        I just updated it to it to the latest firmware and still no luck...
