Bing-Stroller
May 22, 2017Luminary
Release Notes v1.10.1.2
Can someone please point me in the right direction for the release notes (v1.10.1.2)
OR
Summarise what is included?
- gfreyApprentice
I was on an earlier beta version 1.10.0.1 than this release. It fixed my Nestcam and Dropcam disconnects. So this release should have that improved WiFi stability.
- marshymallowApprenticeThis release does not resolve the WIFI drop issue yet. This is officially informed by Netgear in other threads.
- Bing-StrollerLuminaryThanks for that.
I have been relocating cameras earlier and drops seemed to be getting worse.
Hopefully a fix isn't too far off. - OrbiManLuminarySpeed is slower and my phone are not switching between satellites. Not a good upgrade
- Hsc1102ApprenticeThis is WORSE than ever, connection keeps dropping!!!!
Extremely FRUSTRATED!!! - Bing-StrollerLuminaryHave been using WiFi Explorer and it's totally weird.
It goes from a relatively stable line to a totally erratic spiked graph at random intervals. - OrbiManLuminaryHow the heck do you roll back?
- ClintoKLApprentice
Its rubbish like every firmware update so far by the looks. I have no idea how they could possibly have released this product as is.
Alexa drops off all the time. My LIFX bulbs switch on and off by themselves, drop off completely, re-appear. I get massive peaks and troughs in speed. Router doesnt produce the same distance as my 4 year old Asus Router. I have Magenta ring on my Router that no one can explain. I cant login to Router using web or app when the Magenta ring is there.
Its seriously one of the most expensive and poor products available but yet continues to get rave reviews online by thos "tatsemakers" who use the product for 20 mins.
- OrbiManLuminaryThe backhaul speed is also reduced I am getting like 390 mb/s pittyful
- Retired_MemberI really hope the backhaul signal spike problem gains more traction because I think it may be part of the root cause of many of these disconnect issues. What Bing-Stroller saw with Wi-Fi Explorer is the same thing several of us have mentioned in other threads. The backhaul signal from the router drops out, very briefly, but often enough time to disconnect devices.
- Bing-StrollerLuminaryIt seems my system gets progressively worse with every new update.
I had a reasonably stable setup for months, but now its all over the place.
As for the way ahead, I am at a total loss as to whether or not to stick with it or look at alternatives. As to buying another satellite (still waiting for that option in UK) is a not going to happen whilst these problems remained unresolved.- JMU1998Luminary
So far this latest firmware seems pretty useless, waiting on the next version that is being Beta tested, hopefully it has some stability and genuine fixes to offer.
