Bing-Stroller
May 22, 2017Luminary
Release Notes v1.10.1.2
Can someone please point me in the right direction for the release notes (v1.10.1.2) OR Summarise what is included?
OrbiMan
May 25, 2017Luminary
I do agree as well it seems that the router has to learn it environment
- Bing-StrollerMay 25, 2017Luminary
Also on a positive note, my D-Link cameras are not disconnecting as often.
(I had hardwired them into the satellite to minimise WiFi disconnections some time ago).
These cameras are extremely easy to monitor as I receive an email from their servers when the connection is lost.
My frustrations are still there, but when I can see these positive results I feel less likely to project the whole system through the nearest window. :smileywink:
- Retired_MemberMay 25, 2017
That's good to hear Bing. D-Link cameras are my biggest issue. I typically monitor one locally and when it disconnects the blue popup comes up and I have to manually reconnect to keep viewing. I wish they auto reconnected, then the drops wouldn't be as big of a deal.
- fstockelMay 26, 2017Star
It doesn't solve my WAN disconnects (got a supprt case). I loose internet from time to time for aprox 10min each time. The Orbi web interface says "ERROR not connected" when I log in to check. If I bypass the orbi and connect a computer directly to the net everything is ok but with Orbi it isn't.
