Bing-Stroller
May 22, 2017Luminary
Release Notes v1.10.1.2
Can someone please point me in the right direction for the release notes (v1.10.1.2) OR Summarise what is included?
OrbiMan
May 25, 2017Luminary
I do agree as well it seems that the router has to learn it environment
Bing-Stroller
Also on a positive note, my D-Link cameras are not disconnecting as often.
(I had hardwired them into the satellite to minimise WiFi disconnections some time ago).
These cameras are extremely easy to monitor as I receive an email from their servers when the connection is lost.
My frustrations are still there, but when I can see these positive results I feel less likely to project the whole system through the nearest window. :smileywink:
- Retired_MemberMay 25, 2017
That's good to hear Bing. D-Link cameras are my biggest issue. I typically monitor one locally and when it disconnects the blue popup comes up and I have to manually reconnect to keep viewing. I wish they auto reconnected, then the drops wouldn't be as big of a deal.
- fstockelMay 26, 2017Star
It doesn't solve my WAN disconnects (got a supprt case). I loose internet from time to time for aprox 10min each time. The Orbi web interface says "ERROR not connected" when I log in to check. If I bypass the orbi and connect a computer directly to the net everything is ok but with Orbi it isn't.
- Bing-StrollerMay 26, 2017Luminary
Hi BobertSaget,
Re cameras, I have a mix of various brands but the 2 D-Link are a 5222L and a 932L. Both of these auto reconnect after the popup / email notifications.
I cannot remember any additional settings other than the normal registration and setup process that I did when i first installed them. I've just managed to access my PC, had a quick look and I cannot find anything that obviously points to auto reconnect in the settings.
I will try and have another look this weekend with a clear head. ( have spent the day with Medical Cosultants and Surgeon so a bit drained at the moment).
Hopefully a quick fix will get them sorted.
- mccxMay 26, 2017Star
I would to provide some feedback. I have been playing around with different version of the firmware and now I'm running:
Router: v1.10.2
Satellite: v1.11.2 beta
And I have been having very good results. The router no longer restarts every 10-15 mins (had that issue when router is on v1.11.2 beta). The satellite is also working fine, picking up close devices and devices are able to switch between router and satellite. Also, most of my devices are now connecting via 5Ghz.
