LeeP2
May 14, 2026Follower
replacement cord for ORBI RBS50Yv2
the power cord broke at the connection to my orbi outdoor router. It is model AD10330LF. any suggestions on where I can get a replacement? The connector seems unique to the Orbi, since the power c...
CrimpOn
May 14, 2026Guru - Experienced User
LeeP2 wrote:power cord broke at the connection
There are several features of the RBS50Y power supply that are rather unique:
- The weather resistant housing of the transformer
- The screw that holds the power connector to the case
Depending on how the connector is "broken" it may be possible to jury rig a new connector.
- If the cable is broken but some cable remains connected to the plug, then splice the cable.
- If the cable is broken off exactly at the plug, then get an ordinary power supply for the generic Orbi (RBR50),
cut the cable and splice it with the existing cable.
The key is that the plug has to be the same dimensions and polarity as the existing one.
