LeeP2
May 14, 2026Follower
replacement cord for ORBI RBS50Yv2
the power cord broke at the connection to my orbi outdoor router. It is model AD10330LF. any suggestions on where I can get a replacement? The connector seems unique to the Orbi, since the power c...
May 14, 2026Guru - Experienced User
might do a search online or amazon for "orbi rbs50y power adapter"
See if anything will work. The 50Y is EoL so maybe hard to find something exact.
Picture of what adapter real adapter looks like and not genuine adapter:
There is a genuine one advertised here:
But the picture doesn't match, so you confirm with the seller.
CrimpOn wrote:
- The weather resistant housing of the transformer
- The screw that holds the power connector to the case
There's no screw on mine. Though they are both old beta units (not v2).
On weather resistance - the cable itself is also water resistant. You need to be careful to preserve that if you try to splice the cable - especially if the RBS50Y is exposed to the elements.
