Télépermanence's avatar
Mar 22, 2024
Replacement of an RBR 50 V2
Good morning,
I have this "central" with 2 satellites.
The 2 satellites work, but the control unit no longer turns on....
Could you please tell me which model to replace it with so that it continues to work with the satellites still functional?
Thank you in advance and have a good day!
Mark
    • Télépermanence's avatar
      Télépermanence
      Hello, thank you very much for your response and for your help!
      If I understand correctly, it is impossible to find a new device that can take its place? I have to replace everything?
      Thank you so much !
      • FURRYe38's avatar
        New replacements are no longer sold. If you can find previously used models that work, can keep your RBS50s going. If not, Ya, you'll need to get into some new stuff that's out on the market.
