LouisZ's avatar
LouisZ
Follower
Apr 15, 2020
Replacement of RBR 40 router - due to hardware failure -
I have to replace my RBR40 Router part of a 3 satellite configuration. I will call this the original new product install RBK40(Orig)  . The RBR40 (orig)  router damage was verified by Netgear Support staff. The staff advised me to replace the damaged item, after extensive searching we confirmed that I could not purchase a standalone new  RBR40.
I have the following situations
Router replacement and Set up
I found two used RBR40 routers - one a refurbished unit on via Amazon , and a used unit for e-bay.   I will call the eBay RBR 40 router  unit as RBR40 (e-bay) , the second as RBR40 refurbished  RBR40(Refurb)
I noticed that the three satellites  have the password for the RBR40 (orig) , does this imply that I need to some how load the new password from RBR40 (e-bay) .  I am having difficulties setting up the satellites.
I have RBR40 (e-bay) up and running and we noticed a reduction in performance (area-distance) covered.  Is there anyway to check or verified power .
Is there anywhere I can send RBR40 (orig)  For diagnostics and potential repair I need to identify the damage and potential source in the house .
    • Retired_Member's avatar
      Retired_Member
      Please post about this over in the Orbi AC forum:
      what?
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update?
