LouisZ
Apr 16, 2020Follower
Replacement of RBR40 Router in RBK44
I have to replace my RBR40 Router part of a 3 satellite configuration. I will call this the original new product install RBK40(Orig) . The RBR40 (orig) router damage was verified by Netgear Support staff. The staff advised me to replace the damaged item, after extensive searching we confirmed that I could not purchase a standalone new RBR40.
I have the following situations
Router replacement and Set up
I found two used RBR40 routers - one a refurbished unit on via Amazon , and a used unit for e-bay. I will call the eBay RBR 40 router unit as RBR40 (e-bay) , the second as RBR40 refurbished RBR40(Refurb)
I noticed that the three satellites have the password for the RBR40 (orig) , does this imply that I need to some how load the new password from RBR40 (e-bay) . I am having difficulties setting up the satellites.
I have RBR40 (e-bay) up and running and we noticed a reduction in performance (area-distance) covered. Is there anyway to check or verified power .
Is there anywhere I can send RBR40 (orig) For diagnostics and potential repair I need to identify the damage and potential source in the house .
1 Reply
Has a factory reset and setup from scratch on the ebay RBR been performed since you recieved the unit? Same with the one from amazon.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).I don't know if NG has any after warranty repair services.
