creaky's avatar
creaky
Star
Oct 08, 2017
Reset satellite only?
I've done a factory reset via the GUI to try and improve speed. Where I was formerly getting 200+ mbs wireless download speeds I now can't break 100 (I get nearly 300 mbs download speed when Ethernet wired to my ISP modem). If I reset the satellite through the pin hole on the unit will the satellite only reset, or would the GUI reset have taken care of that?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    If you factory reset the satellite it will not affect the main router gui.
    DarrenM
